Civil 3D Forum
AASHTO - Canadian Equivalent?
26 REPLIES 26
Message 1 of 27
2385 Views, 26 Replies
In our LDD version we have Canadian speed tables and standards that we use when creating super elevations. However, in Civil 3D, it seems that we are restricted to using the default AASHTO standards.
Is there an add on or a way to add Canadian standards (in metric) to Civil 3D?
Thank,
Mike
26 REPLIES 26
Message 2 of 27
There is a way. You need to create your own tables and assign them to your
dwg.
Matt Kolberg
GCS - A Division of Cansel
Message 3 of 27
I was hoping for an easier way or a site where I could just download the tables from.
Message 4 of 27
Well, someone may have one done and available, but I'm not aware of one.
Good luck.
Matt Kolberg
wrote in message news:6226281@discussion.autodesk.com...
tables from.
Message 5 of 27
c3dlearner
The work has been done and please wait till Autodesk publish the 2010 Canada Ontario Coutry kit
The tables and xml's are done based on Canada TAC 1999 Metric for both High Range and Low range scenarios
Quantity Take - Off (QTO) pay item data is there as well for both MTO and OPSD
C3DL
Message 6 of 27
And your source for such information is...
Matt Kolberg
Message 7 of 27
c3dlearner
The Canada Ontario Styles Kit for C3D2010 is available to download from the following link
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7271531&linkID=9240698#2010
Some key highlights listed below:
Template
DWT template containing Ontario Civil 3D settings and object/ label styles
Plan Production
Plan, Profile and Plan and Profile (MTO)template sheets
Assemblies
Predefined assemblies for creating intersections
Quantity Take off
Pay Item Data based on Ontario Provincial Specifications categories and MTO Contract Preparation System(CPS)
Network Catalogue
Pipe and Structure catalogue based on Ontario Provincial Standard Drawings
Survey
Figure Prefix Library and Description Keys specific to MTO Surveys and Plans standards
Design Criteria
TAC (metric) design criteria for roadways
AutoCAD Standards
NCS Layers
MTO IESCAD Layers
Linetypes and Hatch Patterns
MTO IESCAD .LIN and .PAT files
MTO Description Keys
MTO Point Marker and Label Styles
MTO Survey Settings and Styles
MTO Alignment Object
MTO Stationing Styles
TAC Design Criteria
TAC Superelevation Tables
Preset “Assembly Set” created for Intersection wizard
Pipe and Structure Labels
Pipe and Structure Rules
OPSD Pipes Catalog
OPSD Pay Items and Categories
MTO – CPS Pay Items and Categories
Also I see the kits for North Carolina and Texas in the link
Regards
C3DL
Message 8 of 27
jybe
C3DL,
Now that we have the CAN Ontario content kit have you noticed that the palettes for it are listed in Russian when you right click on the toolpalette?
jybe
Message 9 of 27
mathewkol
I have that too, vert strange.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 10 of 27
Thanks for catching this. We'll make the corrections and repost the Country
Kit shortly.
Peter Funk
Message 11 of 27
jybe
Peter,
There is one other issue. When you first start up the MTO version it is looking for a shx file that does not exist.
Cheers,
jybe
Message 12 of 27
We'll check that out as well...
Peter Funk
Message 13 of 27
jybe
Peter,
For those of us that do C3D training in Ontario Canada, the MTO (Ministry of Transportation) content kit is a great addition. We do have a slight problem though, that being no documentation to back up anything in the kit (layer schemes, etc.). I had a friend send me over a copy of the MTO AutoCAD Standards Guide v2.1, May 2000. Is there anything more current that Autodesk can provide or do we have to contact the MTO?
jybe
Message 14 of 27
c3dlearner
The Canada Ontario Kit build should install the "document" and not sure what happened, anyways I have a copy of workbook and the file size is too large to attach in this group. I am away from town on a C3D consulting mission at a remote location in western Canada and using the Canada Kit for the training and my students are loving it 🙂
Post your e-mail and I could pass it along
C3DL
Message 15 of 27
jybe
jybe@cadland.com Edited by: jybe on Aug 13, 2009 5:21 PM
Message 16 of 27
mathewkol
While we're on the subject of suggestions;
1. The DWT is not in line with the others in the folder. Renaming it with an underscore would place it at the top with the rest. Honestly, if I were using this DWT I would place it in some other folder on the network anyway, but to be consistent...
2. The pay item file cannot be located. (see image)
Matt
Matt Kolberg
Message 17 of 27
Dylan_Corkill
Hey everyone I just downloaded and installed this country kit and noticed that the palettes are still in Russian, the mt-ltype.shx file that it's looking for is actually the mt-ltype_caon.shx file and it doesn't seem to install the mtoeng.shx file at all. I have yet to find any documentation about this country kit on my system. All I have found is the install logs.
Message 18 of 27
TheCanadianPrimate
Peter,
Just downloaded this, as of Oct 8 2009 it seems none of the above problems have been addressed.
Message 19 of 27
jwhal
Without trying this, is it possible to get the TAC tables installed an working for Civil 3D 2009? Not all of our techs have the hardware to run 2010 yet, and I can't convince our IS department to install 2010 on my machine only...
Jon
Message 20 of 27
c3dlearner
The following files from the install bundle will do the job for 2009 version
Locate "Canada TAC 1999 Metric (High Range)_CAON.xml" and "Canada TAC 1999 Metric (Low Range)_CAON.xml" and assign appropriate file in the "design criteria editor"
C3DL
Rail Community
