Hi there, in autocad civil 3D, there is a A value for alignment design. What is the difference between A value and K value?
Solved by Joe-Bouza. Go to Solution.
A= that algebraic difference of the grades going in an coming out of a vertical curve.
K = the rate of change of a vertical curve
L= the length of a vertical curve
K=L/A
A= g1-g2
AASHTO has these definition and recommendations for vertical curves based on design speed, sight distance etc.
Joe Bouza
Thats Right! I cant decide on Sweet or Savory.
Joe Bouza
