Hi Rob,
Set the surface view of a copy of the surface to the triangles and explode
as often as you need to end up with 3D faces.
Laurie Comerford
CADApps
www.cadapps.com.au
"Rob Pickers" wrote in message
news:5110028@discussion.autodesk.com...
A quick question - once you created a surface - can you then convert or save
the surface as 3D faces?
Your help is much appreciated
rOB
