Civil 3D Forum
A note for People Importing 12DA files
25 REPLIES 25
Message 1 of 26
ceethreedee.com
16593 Views, 25 Replies
If anyone has been trying to use the 12DA import extension for Civil 3D. Read on!
I have been having problems importing latest 12DA files. It doesnt import anything for some reason.
A simple change to the 12DA files encoding fixes the error. Get NOTEPAD ++ Download Here
Old 12DA files encoded with "UTF-8 without BOM" will work. However new ones encoded with "UCS-2 Little Endian" won't convert them and save as shown below. All working again!
Kapanther 🙂
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
25 REPLIES 25
Message 2 of 26
lim.wendy
in reply to: ceethreedee.com
That's good to know!
Thanks for sharing the workaround! Smiley Happy
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 3 of 26
ceethreedee.com
in reply to: lim.wendy
No probs...
Infraworks 2021.1,
ceethreedee.com
Message 4 of 26
lem_1020
Wow this is great. Saved this way it actually allows you to open new version 12da projects in old 12d model versions also.
Message 5 of 26
ceethreedee.com
in reply to: lem_1020
nuts... double bull bonus!! Smiley Wink
Kapanther
Infraworks 2021.1,
ceethreedee.com
Message 6 of 26
does not work for me. What am I doing wrong.
Mike
Message 7 of 26
rkmcswain
Please create an Autodesk KB article for this. Thanks.
Message 8 of 26
Did you download notepad++ to re encode?
Infraworks 2021.1,
ceethreedee.com
Message 9 of 26
cromo23
I'm trying this importer for 2015, have re-encoded but seem to not work for me.
Just trying a 4 string Super Alignment String and Leaving Import option as default
So something simple
Getting errors of "mismatched number of H geometry records" what ever thats means.
Cheers Rob
Tags (1)
Message 10 of 26
ceethreedee.com
in reply to: cromo23
Attached the file if you want.. I will take a look.
You did press "convert to UTF...
rather than "encode as UTF.
There are still some issues importing 12DA super alignments though. The importer probably needs some updating!
Infraworks 2021.1,
ceethreedee.com
Message 11 of 26
Just a quick note that this solution only really works for 12D V10 it will not work on V11 files. I believe an update is been worked on as we speak..
I'll post more here and on my blog when there is an udpate..
Infraworks 2021.1,
ceethreedee.com
Message 12 of 26
I am trying to import some 12da data in Civil 3D2016. The version that we use for 12D is V11 and as you say in the previous post, your solution does not work for that version.
Do you have any update to solve this problem?
Thank you!!!!
Almudena
Message 13 of 26
Well you have two options.
Option A
Write out to the old 12da version (in the output menu down the bottom you will see there is a "12da old version" option there somewhere)
Option B
Write to a genio file. I have found this works better. Make sure you tick on option to convert super alignments etc.
Regards
Infraworks 2021.1,
ceethreedee.com
Message 14 of 26
Thanks this worked for an import into 3DS Max
Message 15 of 26
UPDATE - For versions 2017 adn greater of Civil 3D. The importer has been updated and you no longer need to use this encoding trick.
Note you may need to get the 12d operator to export the file using 12da old version though..
Addiional note. 12DAz files are just a zip file that contains a 12da file. change the extension to zip and then unzip the 12da file.
Infraworks 2021.1,
ceethreedee.com
Message 16 of 26
adw1975
I've been trying to use this converter both ways (from 12d v12 and from Civil 3d 2017 & 2018). But having no luck at all.
Are you saying the version of 12d isn't compatible with the Extension? and I might have to roll back to Version 10 of 12d?
Message 17 of 26
paolo81d
12D IMPORT will not run at all and get an error as per the below image.
Message 18 of 26
ceethreedee.com
in reply to: adw1975
Ive found the only way to get this to work is either.
A. Export genios
B. Export V9 12da files (output menu -> old formats -> 12da old format. I
think ftom memory
C. Pay extra and get the landxml exporter..
Infraworks 2021.1,
ceethreedee.com
Message 19 of 26
ceethreedee.com
in reply to: paolo81d
Yep this is no longer valid.
Infraworks 2021.1,
ceethreedee.com
Message 20 of 26
adw1975
So would this mean that the surveyors I am sending 12da files to would need to have 12d version 9 not 12?
Thats if I were to export the old file as I don't have either of the Genio or LandXML export licences.
Rail Community
