Nothing is symetrical here. The primary road is running upper left to lower right. The intersection is also in SE. I created left an right A & P from the corridor ETW. Due to lack of symetry I have two secondary alignments. I ran the corridor and got some zero contours in two quads, but the targets seem right; the ETW A & P, thats not my question though.
one of the secondary profiles is not locking to the primary. is there a manual way yo get a profile to lock?
Solved by Joe-Bouza. Go to Solution.
Allegedly, it is a known issue with 4 way intersections and multiple side street alignments render empty return profiles. My work around was to leave the through road corridor, and build the intersection manually.
You are right Joe, you can't use the intersection wizard to model an intersection where 2 side road alignments meet at the main road. You'll have to model them manually.
Keep eating that elephant.
