Civil 3D Forum
3d Printing a site.
6 REPLIES 6
dla4y4
875 Views, 6 Replies
3d Printing a site.
I want to print off a site using a makerbot that contains some retaining walls as a present for our client. I was hoping to use 123D to print it off to a makerbot, but I have been unable to load a drawing in it. I am curious if anybody has tried to 3d print a site, and if so what tricks you have used. I am currently trying to make a solid from a surface and see if that will export.
6 REPLIES 6
antoniovinci
in reply to: dla4y4
You should look for a stereolithography service in your town, then give them a .STL version of that site.
To create a .STL file, you can use the _STLOUT command (it works on solids and watertight surfaces).
If somehow you cannot, try to create the .STL file by means of the italian opensource Meshlab.
dla4y4
in reply to: antoniovinci
I am hoping to do this by myself for the most part. I have access to a Fab Lab here in Tulsa, with a few 3D printers and such.
What I have now is a surface, as in contours turned into a surface. None of the stuff I have read have been for doing what basically amounts to a site layout. I spent some time last night trying to get it ready to be exported, but nothing worked out too well. I am unsure of how to make a solid of a surface
AllenJessup
in reply to: dla4y4
Try Convert a Civil 3D Tin Surface to AutoCAD Solid.
Allen
Allen Jessup
CAD Manager - Designer
NathanBee
in reply to: dla4y4
If you do get it to work, could you please post some images of the finished product here please? Cat Very Happy
Joe-Bouza
in reply to: NathanBee
I second that
Your Name
Your Name
dla4y4
in reply to: AllenJessup
This was the step I needed. Was able to turn into a solid. Will take me a while to work on it from there, but it can import into 123D now I think. And I will post an update once I figure this all out.
Rail Community
