Oops, forget the screen grab.
Laurie Comerford
Laurie wrote:
> Hi Rafael,
> Did you use the attached form to add the 3DFaces to your surface model?
> If you did and never saw any errors, then all that has happened is that
> your surface display is set not to display the triangles.
> Right mouse click on the surface in the Prospector and select "Edit
> Surface Style". That way you can adjust the object visibility so you
> can see any components of the surface you wish.
> To Keith,
> There is nothing wrong with using 3DFaes to build a surface model. As a
> design tool drawing 3Dfaces is probably harder than drawing feature
> lines. Editing 3DFaces certainly is harder.
> To Vladimir & Keith,
> Unless you are using Land Desktop which couldn't use 3DFaces as part of
> a surface model definition, why would you want to convert the 3DFaces to
> lines?
> 3DFaces are amongst the best source data for building a surface model if
> you toggle the "Maintain Edges from Objects" on.
> There are two issues with the conversion.
> You can't explode 3DFaces to lines without first converting the 3DFaces
> to Regions, then exploding the regions.
> After exploding the Regions from a set of 3DFaces you then have
> duplicate lines which have to be cleared up with Map before adding to
> the surface.
> Regards,
> Laurie Comerford
> RafaelMoreno wrote:
>> I am trying to define my surface with two 3D Faces and it looks like the surface does not acept this definition. Even that they show up in the definition tab, they do not show up in my object viewer when I pick up the surface -see first screen shot in Word document-
>> The objects are display in the second shot in word document when I pick up my drawing objects. If it is not the best way to define my ramp, how is possible to define it then?
>> Thanks in advance
>> Rafael Moreno
