So, I just talked to my IT guy, and it looks like I could be getting a 64-bit machine sometime this year!
A couple of others will be updated too, but probably not on the same day. And others will be waiting for another couple of years still. Therefore, a couple of questions arise.
Am I going to see any problems of non-compatibility between 32 and 64 bit machines on the same network? We don't use vault, but we have x-reffs, d-reffs, sheet sets and multiple people working on different drawings in the same project at the same time, all referencing each other in various ways. The same drawing will be passed back and forth and worked on by different people. Are we going to have problems (I mean in addition to our normal problems )?
Currently running 2008 (rarely), 2011 (normally), and 2013 (increasingly).
Thanks!
Mark Green
Working on Civil 3D in Canada
Solved by michael.robertson. Go to Solution.
Solved by sboon. Go to Solution.
Solved by mathewkol. Go to Solution.
When we started mixing XP 32 bit systems with newer computers running 64 bit Vista and later Win 7 we found that the newer OS could easily create and use drawings that exceeded the memory capacity of XP. Our designers using the newer systems could create drawings that the drafters had trouble working with.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
The bit version of the OS is not going to change the format or the functionallity of the Autodesk files themselves. But as another person pointed out, large files will be more stable on 64bit systems.
Also, you may need 2 versions of some addon applications, you can't run 32bit ObjectARX on 64bit machines and vica-versa.
FYI, C3D 2014 is ONLY 64bit if you get to that point.
Mark Green
ObjectARX are programs that are loaded via the Appload command when you select a "arx" file. These types of programs are bit version specific. Note: these files may be loaded automatically when C3D starts.
This is normally 3rd party software loaded on top of AutoCAD and/or Civil3D.
Well, it finally happened! And less than 12 months from my initial post too!
I upgraded from this:
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM
to this:
Win 7 Pro, 64 bit; Intel Core i7 @ 3.50GHz; 8GB RAM
Not a supercomputer, but definitely a step up. Things don't feel twice as fast as previously, but it is faster. And I haven't crashed it yet in the few weeks I've had it.
Thanks to those who replied when I was wondering about this.
Mark Green
