AutoCAD Civil 3D General Discussion
Valued Mentor
kevin.barnett
Message 1 of 6 (263 Views)
Accepted Solution
2015 Object Properties Display (2)... what is this?
263 Views, 5 Replies
04-11-2014 01:37 AM
Civil 3D 2015
Could be Map 2015
Not AutoCAD 2015
The Properties palette has an aditional tab: Display (2)
Object control by display system ?  What is this? How does it work? Will it make my life extremely better?
Distinguished Mentor
michael.robertson
Message 2 of 6 (246 Views)
Re: 2015 Object Properties Display (2)... what is this?
04-11-2014 04:15 AM in reply to: kevin.barnett
Not seeing that on my 2015, only the other 4 tabs. Do you have any custom software loading along with C3D?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Valued Mentor
kevin.barnett
Message 3 of 6 (230 Views)
04-11-2014 06:26 AM in reply to: michael.robertson
: (   no .. nothing additional installed.. except .. Country kits for ANZ and UKIE
This tab even appears in DWG's started using no template ...
Wierd!!
*Expert Elite*
rkmcswain
Message 4 of 6 (225 Views)
04-11-2014 06:47 AM in reply to: kevin.barnett
.....and I'm still trying to figure out what the regular "Display" tab is for... not to mention the "Object Class" tab....
*Expert Elite*
neilyj
Message 5 of 6 (212 Views)
04-11-2014 08:01 AM in reply to: rkmcswain
I'll second that...:smileyhappy:
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
*Expert Elite*
Murph
Message 6 of 6 (191 Views)
04-11-2014 03:44 PM in reply to: rkmcswain
Both of them are used in Map3d, the display tab is used for differnt maps create in the single dwg.The object class is for classified objects. Well I better say that's WHAT they used to be for.
Murph
Supportting the troops daily.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
