Civil 3D 2015
Could be Map 2015
Not AutoCAD 2015
The Properties palette has an aditional tab: Display (2)
Object control by display system ? What is this? How does it work? Will it make my life extremely better?
Solved by Murph_Map. Go to Solution.
Not seeing that on my 2015, only the other 4 tabs. Do you have any custom software loading along with C3D?
: ( no .. nothing additional installed.. except .. Country kits for ANZ and UKIE
This tab even appears in DWG's started using no template ...
Wierd!!
@rkmcswain wrote:
.....and I'm still trying to figure out what the regular "Display" tab is for... not to mention the "Object Class" tab....
Both of them are used in Map3d, the display tab is used for differnt maps create in the single dwg.The object class is for classified objects. Well I better say that's WHAT they used to be for.
