Using 2014 SP1, we have “Parent” drawing and “Child” drawing, both were started from the same template. Parent contains a pipe network, with a data shortcut created for it.
We open “Child” drawing and d-ref in this pipe network, taking care to select the proper Parts List – and everything looks great. But, the first time we sync the pipe network, the style assigned to the pipes changes (to something unwanted).
We have:
....and nothing works.
Then I open “Child” in 2013 SP2, delete the pipe network, create the d-ref to it again then sync. The styles DO NOT change, and everything is fine.
So what is the difference between 2014 SP1 and 2013 SP2?
Why are the styles changing in 2014 only?
TIA
(FWIW, I have researched a few threads here and at augi regarding the possibility that the two drawings do not share the same parts list, etc. - and have taken care to make sure that is not the cause in this case)
This is a major PITA. I would prefer to have the option to synchronize and either synchronize w/ styles or synchronize and maintain ex. styles, somewhat like the visretain variable for xrefs. Although I guess I would just settle for functional synchronization...although I don't expect to see that for a couple of years, if ever. Must be nice to have a monopoly on the industry.
