AutoCAD Civil 3D General
sboon
Message 1 of 15 (1,089 Views)
2013 bug - corridor feature lines
1089 Views, 14 Replies
04-17-2012 11:00 AM
I have a road corridor with feature lines connecting the road edges (cyan), ditchline (dark green), daylight_cut (yellow), daylight_fill (green) and daylight (white).  At certain random locations along this corridor I am getting feature lines which span from one station to another, ignoring all of the corridor sections in between.  The image below shows a daylight_fill line spanning over 60m, even though there is a daylight line through this region.
In this area a ditch line and a daylight_cut start at 4+110, skip over the next cut section at 4+120 and jump over a hundred meters to the next piece of ditch at 4+280
This corridor builds clean - no error messages reported.  Is anybody else seeing this behaviour?
Employee
dana.probert
Message 2 of 15 (1,075 Views)
Re: 2013 bug - corridor feature lines
04-17-2012 01:00 PM in reply to: sboon
Can you post the dwg? or a sample dwg?
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
sboon
Message 3 of 15 (1,066 Views)
04-17-2012 01:23 PM in reply to: dana.probert
Not on a public board Dana, but PM me and I'll arrange to get it to you somehow.
Employee
dana.probert
Message 4 of 15 (1,015 Views)
04-19-2012 11:17 AM in reply to: sboon
Can you make it fail in a tutorial or sample dwg?
You can email me the dwg if you like and I can see if I can get it looked at. First dot last at youknowwhere.com
Dana Probert, P.E.
Distinguished Contributor
bigblittlerent
Message 5 of 15 (1,002 Views)
04-19-2012 11:43 AM in reply to: sboon
In the Feature Lines tab of corridor properties...Does Branching Inward or Outward make a difference?
Brent
sboon
Message 6 of 15 (998 Views)
04-19-2012 11:55 AM in reply to: bigblittlerent
Nope.
Employee
dana.probert
Message 7 of 15 (995 Views)
04-19-2012 11:57 AM in reply to: sboon
I know that you have probably checked this... but just looking at your screen capture, I have to ask.
Is there a corridor surface in your dwg with the border only display on?
Dana Probert, P.E.
bigblittlerent
Message 8 of 15 (994 Views)
Steve,
To answer your previous question...Yes, I saw this a few times...branching outward solved it for me a couple times.
Good luck.
Brent
sboon
Message 9 of 15 (990 Views)
04-19-2012 12:08 PM in reply to: dana.probert
No surface Dana.  The green lines are Daylight_Fill feature lines, the yellow ones are Daylight_Cut, and the white ones are Daylight codes.  The darker green ones parallel to the Daylight_Cut  are the Ditch codes.
bigblittlerent
Message 10 of 15 (985 Views)
04-19-2012 12:16 PM in reply to: sboon
Steve,
Was the assembly built in 2013?...have had problems mixing subassemblies from different versions of software.
Brent
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
