Civil 3D Forum
2013 bug - corridor feature lines
14 REPLIES 14
Message 1 of 15
sboon
1586 Views, 14 Replies
I have a road corridor with feature lines connecting the road edges (cyan), ditchline (dark green), daylight_cut (yellow), daylight_fill (green) and daylight (white).  At certain random locations along this corridor I am getting feature lines which span from one station to another, ignoring all of the corridor sections in between.  The image below shows a daylight_fill line spanning over 60m, even though there is a daylight line through this region.
In this area a ditch line and a daylight_cut start at 4+110, skip over the next cut section at 4+120 and jump over a hundred meters to the next piece of ditch at 4+280
This corridor builds clean - no error messages reported.  Is anybody else seeing this behaviour?
Steve
Expert Elite Alumnus
14 REPLIES 14
Message 2 of 15
dana.probert
in reply to: sboon
Can you post the dwg? or a sample dwg?
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
Message 3 of 15
sboon
in reply to: dana.probert
Not on a public board Dana, but PM me and I'll arrange to get it to you somehow.
Steve
Message 4 of 15
dana.probert
in reply to: sboon
Can you make it fail in a tutorial or sample dwg?
You can email me the dwg if you like and I can see if I can get it looked at. First dot last at youknowwhere.com
Dana Probert, P.E.
Message 5 of 15
in reply to: sboon
In the Feature Lines tab of corridor properties...Does Branching Inward or Outward make a difference?
Brent
Message 6 of 15
sboon
Nope.
Steve
Message 7 of 15
dana.probert
in reply to: sboon
I know that you have probably checked this... but just looking at your screen capture, I have to ask.
Is there a corridor surface in your dwg with the border only display on?
Dana Probert, P.E.
Message 8 of 15
in reply to: sboon
Steve,
To answer your previous question...Yes, I saw this a few times...branching outward solved it for me a couple times.
Good luck.
Brent
Message 9 of 15
sboon
No surface Dana.  The green lines are Daylight_Fill feature lines, the yellow ones are Daylight_Cut, and the white ones are Daylight codes.  The darker green ones parallel to the Daylight_Cut  are the Ditch codes.
Steve
Message 10 of 15
in reply to: sboon
Steve,
Was the assembly built in 2013?...have had problems mixing subassemblies from different versions of software.
Brent
Message 11 of 15
sboon
The assembly was imported from a 2012 file, but I've recreated the whole thing from scratch using 2013 subs - no effect.
Steve
Message 12 of 15
sboon
in reply to: sboon
While adding the new 2013 subs to a new assembly I did notice that the 2012 version uses a different parameter list than the 2013 sub.  It doesn't solve the problem but does suggest that bringing old assemblies forward to 2013 should not be recommended.Clipboard01.png
Steve
Message 13 of 15
in reply to: sboon
Steve,
I have been struggling with the same problem for the past couple of weeks. The solution I found is to split my corridor into smaller regions where the rogue feature lines are happening.
Tim
Message 14 of 15
Wlewinski
in reply to: sboon
I opened the "Creating Multiple Section Views.dwg" from the book Mastering civil3d 2012 using Civil 3D 2013 and the same thing happened, feature lines cross through ignoring multiple sections. I think it may be a graphics (visual) thing, The surface created from it seems normal. Also, changing the frequency will make it change or disappear.
Walter M. Lewinski, P.E.
Solution Specialist - Civil
MICRODESK, INC.
(800) 336-3375
Message 15 of 15
sboon
in reply to: Wlewinski
If the corridor surface is built from links only then the crossing feature lines aren't a problem, but if they are used either as part of the surface definition or the boundary then it goes fubar.
Steve
Rail Community
