Civil 3D Forum
2013 View from bottom
12 REPLIES 12
Message 1 of 13
sjg
567 Views, 12 Replies
Has anyone else having issues with 2013, somehow switching to bottom view. Open a drawing and everything looks normal except when I look at the viewcube and I am looking up from the bottom.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
12 REPLIES 12
Message 2 of 13
sboon
in reply to: sjg
Might be the issue solved in this thread.
Steve
Expert Elite Alumnus
Message 3 of 13
neilyj666
in reply to: sjg
I've certainly noticed this behaviour so I added lines in my acaddoc.lsp to turn off the viewcube
2013-04-16 10_30_45-AutoCAD Civil 3D 2013 - [010 INDICATIVE SUBSTATION LAYOUT.dwg].jpg
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 13
autoMick
in reply to: sjg
Use GEOGRAPHICLOCATION to reset your -Z to +Z
I've no idea why it does that.
Civil3d user in Australia since 2012.
Message 5 of 13
sjg
in reply to: neilyj666
I didn't really notice until our survey department was going to do some stakeout from our engineering drawings. Put in some points and the coordinates were way off. I am just a lot more concious of what view I am in.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 6 of 13
sboon
in reply to: sjg
The GEOGRAPHICLOCATION tool is supposed to affect the transfer of data to and from Google Earth.  If I read the help file correctly it's not supposed to have any affect on Civil3D points going to or from survey.  Are you sure that this bug was the cause of your problem?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Message 7 of 13
sjg
in reply to: sboon
I didn't mess with the GEOGRAHPICLOCATION, survey department uses Carlson so when they opened the drawing, it looked fine, started placing points then they realized coordinates were off. Not sure if new hotfix would resolve the view change.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 8 of 13
HansSMS
in reply to: sjg
Type GEOGRAPHICLOCATION and set it off in the ensuing dialog. This will get the viewcube to display correctly. Setting the geographic location correctly doesn't work because somewhere later the system changes it to rubbish and the viewcube goes funny again.
Best to do this in all  your templates as well.
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
Message 9 of 13
Jeff_M
in reply to: sjg
I had thought that SP1 corrected this.
Jeff_M, also a frequent Swamper
Message 10 of 13
troma
in reply to: Jeff_M
I thought I has SP1 installed, but I just got this 'view from bottom' problem.  First 5 mins of working in 2013.  How do I figure out if the SP is installed?  I type ABOUT but I don't see any info on the SP.
So what I'd like to know is: is this going to actually affect anything?  If I d-ref something out of this drawing, is it going to be junk?  Or is it just a viewcube glitch that I don't care about because I'm going to turn of the viewcube anyway?
Thanks!
Mark Green
Working on Civil 3D in Canada
Message 11 of 13
Jeff_M
in reply to: troma
Message 12 of 13
troma
in reply to: Jeff_M
Thanks Jeff.  I just crashed and did the CER and was told that I didn't have the SP, so that's confirmation.  (Actually, I didn't really crash.  I closed the program down myself, and then the Error Reporting window was there.  Seems to happen now & then.)
So the SP will be the first priority.
Any idea about the other question: does this glitch actually harm anything, or just make the viewcube look weird?
Mark Green
Message 13 of 13
Jeff_M
in reply to: troma
I don't know whether it really affects anything in C3D. It may have an impact on importing Georeferenced images, but I still use 2012 as my main platform so never looked into it too much.
Rail Community
