I extracted a dynamic feature line from the gutter flowline of my Corridor. I labeled Multiple Segments for the feature line with a grade and vertex style that uses the "General Segment Grade" text component.
I am overiding lane cross slopes in the Section Editior and the segment grade labels for the extracted feature line do not update after I Update Corridor in the Section Editior.
If I raise/lower the CL profile of the corridor, the label updates. Just not reacting to these Corridor edits.
Peculiar behavior: The label will update to reflect the Corridor update if I Isolate it.
Solved by fcernst. Go to Solution.
Fred, just fyi, this works correctly in 2013.
It's not working for me in 2013. It's behaving as I describe.
Hi Tim,
I've isolated this to the Update Corridor command within the Section Editor. The Update Corridor command is rebuilding the corridor, updating the surface, updating the Section View, etc., like it should, however the feature line labeling is not updating on this extracted dynamic feature line.
If I then select the Corridor and Rebuild it from the command on the Corridor tab, the labels update.
Thanks for the follow-up. That's good to know. I'll file that in my (short-term?) memory.
