I guess I've over looked this for a while but I'm tweaking out dwt file and I am noticing that the default lable and pipe style I have set in the network defaults is not being honored. Am I setting this in the wrong place or is this a know isssue?
Your Name
Think you need to click the child overide column to force the styles down the chain if command.
I typically go right to the commands and change the defaults there.
John Mayo
Perhaps my 3 weeks away from a computer mixed with my lack of coffee yet this morning has me thinking incorrectly, but.... Aren't the pipe & structure styles controlled by the Parts List? As for the StructureLabelStyle, I see the arrow in the Child Override column. Clear this to insure the desired style is used, or do as John said and make the changes to the Command settings.
Your Name
Perhaps they are, but if I new that, I probably wouldn't need to ask 🙂
As for the child over ride - didn't even know I had one.
Ah ha! I se my part list said one thing and the feature settings another. I guess the tale wagged the dog on this one.
Your Name
