Civil 3D Forum
2012 Transportation Extension
7 REPLIES 7
Message 1 of 8
cjkiefer02
1223 Views, 7 Replies
I am trying to install the 2012 Transportation Extension and when I go to use it I get an error that states
"Execute File is not exist: C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\net\C3DReportTE.dll, please reinstall program"
I have uninstalled 2012 Civil3D and reinstalled but still cannot get it to work.  It works just fin in 2011.
Colton
7 REPLIES 7
Message 2 of 8
AlmasSuljevic
in reply to: cjkiefer02
It seems that the file C3DReportTE.dll does not exist in the directory C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\net\
See if you can make a copy of C3DReport.DLL (same directory) and rename that copy to C3DReportTE.dll and then restart Civil 3D. See if the message will go away.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 8
cjkiefer02
in reply to: AlmasSuljevic
It dies work that way but the original report from  C3DReport.DLL is different than the report from C3DReportTE.DLL.
Message 4 of 8
cjkiefer02
Here is a screen shot of the 2011 TE box and the 2012 standard report box.
Message 5 of 8
AlmasSuljevic
I see the difference. My suggestion was in line that the C3DReportTE.dll was missing and renaming other DLL would allow it to run. Can you copy the 2011 version of the transporation extension C3DReportTE.dll to 2012 directory? That should work too.
Almas Suljevic
Autodesk, Inc.
Message 6 of 8
cjkiefer02
I tried that also.  It is pulling from another file that I cannot seam to find.
Message 7 of 8
AlmasSuljevic
I reported this issue to the development and hope to see the new version posted in the near future.
Almas Suljevic
Autodesk, Inc.
Message 8 of 8
Kevin.Spear
Any resolution to this?
Kevin
Kevin Spear, PE
Rail Community
