Civil 3D Forum
2011 Survey Database does not exist and could not be recreated
4 REPLIES 4
Sinc
1658 Views, 4 Replies
This one got me and took a fair while to figure out, so I thought I'd post about it.
I was attempting to create a new Survey Database, and kept getting an error "The survey database does not exist and could not be recreated", with a message that "Format of the initialization string does not conform to specification starting at index 58."
I finally tracked the problem down to an apostrophe in the name of one of the folders in my Working Folder path.  This was not a problem with C3D 2010 and earlier, but is evidently a problem starting with C3D 2011 (and it may only affect the 64-bit version, I don't have a 32-bit version handy to test).  Renaming the folder, so that there was no longer an apostrophe in the folder name, solved the issue.
Sinc
4 REPLIES 4
Sinc
in reply to: Sinc
Posting a reply, just to see if I can flag this thread as "solved"...
Sinc
mathewkol
in reply to: Sinc
Nice.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
jporter
in reply to: mathewkol
So I guess it's safe to say it was never solved? ? ? ?  I got  a user with the same issue in Civil 3D 2015.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
jporter
in reply to: jporter
Just an FYI - on my end the issue was that the user had named the project folder with an apostrophe in the name.  I removed the apostrophe and the error disappeared.
Jason Porter
www.asti.com
Rail Community
