I am working now in 2011. The panorama for editing a pipe nework is showing me the wrong network and nothing I do will allow me to see the correct network. The edit network toolbar shows the correct network but the panorama is referencing a different network. This happened all the time in 2010 and I could get it to work. However, the 2010 work arounds don't seem to work in 2011. Any suggestions.
Solved by klugb. Go to Solution.
First off, it's a BUG.
My workaround.
Select a network from the toolspace.
rt-click - edit network
Hit the pipe network vista (Panorama window)
NOW
to switch between networks
rt-click on next network, and you see the layout tool box change but not the panorama.
close and re-open using the button on the bar DO NOT USE THE "X" on the panorama.
That's the bug, it has to be closed using the button on the layout tool box.
See video:
http://screencast.com/t/NDNlYjQzMDA
Bruce
The way that I've found it works is when you open the Edit Network toobar for the first time and then click and open the Panorama you have to close the toolbar which closes both the toolbar and the Panorama at the same time, then you can go and select another Pipe Network to edit without a problem. If you open the toolbar and then the Panorama and then close the Panoramafirst and then the toolbar, the next time you edit another Pipe Network it will still show the last Pipe Network information in the Panorama even though the name of the Pipe Network that you want to work on is shown in the toolbar title bar.
