AutoCAD Civil 3D General
Distinguished Contributor
DaveDrahn
Message 11 of 12 (502 Views)
Re: 2011 Civil 3D - Program freezes often. Hatching takes forever!
05-27-2011 04:30 PM in reply to: brad_in_omaha
for the hatch problem, besides the Preview mode var (good one, thanks guys), keep you properties dialog box off or closed when youre selecting - it really hangs CAD consistently if open and selecting complicated hatching or polys
In options->selection tab, turn off selection highlighting
turn off any other tool tips and heads up display
For dwg slowdown issues:
make sure you're purging regularly, and use the -PURGE (dash purge) command so you can specify to purge RegApps.  Carlson and EaglePoint especially add 10's of thousands of regapps and they can slow you down.
reset your scale list every now and then - the _xref scales issue from 2008 is still being carried forward and can dogg you.  Use SCALELISTEDIT and Reset.  The scale list'll slow down a dwg at some point.
Also, in general:
make sure you have the latest SP - 2.1 I think.  That's made a lot of difference for us.
Max your RAM out if you're on Win7x64 - 8-12G seems nice
Get a good video card and update the drivers for it diligently
nc
Member
nc
Message 12 of 12 (427 Views)
09-09-2011 03:17 PM in reply to: BillElam5439
This may be a new one, but C3D will lock up everytime on the hatch command or attempt to stretch the boundary of an existing hatch if I have collopsed/minimized the ribbon to panel buttons or titles. As long as the hatch creation ribbon is expanded/visible, no issues.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
