AutoCAD Civil 3D General
Distinguished Contributor
MtnMax700
Message 1 of 11 (264 Views)
2010 to 2013
264 Views, 10 Replies
04-16-2012 12:02 PM
I just got word that we are making the jump.  Only had 2010 a year.  What kind of problems ae we looking at?
Thxs.
David
Message 2 of 11 (255 Views)
Re: 2010 to 2013
04-16-2012 12:23 PM in reply to: MtnMax700
Biggest may be that a lot of labels lose their connections when upgrading, and turn into a "broken" label that includes a GUID instead of the connection to the correct field.  There was also a change in C3D 2011 that caused some Parcel labels to appear at the wrong offset from the Parcel line, vs. in C3D 2010 and earlier.  And if you've been creating custom Reports or Subassemblies, you may have a lot of problems with those, as well.
Sinc
MtnMax700
Message 3 of 11 (249 Views)
Re: 2010 to 2013
04-16-2012 12:33 PM in reply to: MtnMax700
Will my templates go across?
Message 4 of 11 (245 Views)
Re: 2010 to 2013
04-16-2012 12:40 PM in reply to: MtnMax700
For the most part, except for the fact that some of your Styles may "lose" their connections and turn into GUIDs, as mentioned in my last post.
Also, there have been some new features added, which involve new Styles.  So if you simply migrate your 2010 template to 2013, you may find that you have to manually create some Styles for some of the new features (or copy them into your template from one of the stock C3D templates).
Sinc
Message 5 of 11 (219 Views)
Re: 2010 to 2013
04-16-2012 03:20 PM in reply to: MtnMax700
The way section views are organized was significantly changed from 2010 to 2011.  Opening a 2010 file with XS views will probably result in them moving, especially if you've moved some of the views manually.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
MtnMax700
Message 6 of 11 (202 Views)
Re: 2010 to 2013
04-16-2012 04:14 PM in reply to: MtnMax700
Sinc,
What's a GUID?
Thxs.
David
Message 7 of 11 (187 Views)
Re: 2010 to 2013
04-16-2012 08:51 PM in reply to: MtnMax700
I think it means "Globally-Unique Identifier".  It's a VERY long string of letters and numbers, which is typically used in Microsoft Windows-based software.  It's created in such a way that it will ALWAYS be unique, no matter how many people try to create them.  You'll see a whole bunch of them if you go into REGEDIT and poke around...  Virtually everything in Windows has a GUID.
The format is something like this (and here's one I JUST generated...):
6d8fd0e0-7d84-4c70-9f7f-2a77831f274e
When your C3D labels get corrupted, which seems to happen in upgrades from C3D 2010 (and earlier) to later versions of C3D, you'll see your label values replaced with strings like that.
Sinc
Message 8 of 11 (186 Views)
Re: 2010 to 2013
04-16-2012 08:55 PM in reply to: Sinc
Oh, and I suppose it should go without mentioning that if you poke around in REGEDIT, be berry berry careful...  Der's wabbits in there....  :smileyhappy:
(In other words, you can SERIOUSLY mess up your system if you do the wrong thing.)
Sinc
Message 9 of 11 (167 Views)
Re: 2010 to 2013
04-17-2012 05:00 AM in reply to: Sinc
To find all the new styles or those that changes for each release, 2011, 2012, and 2013, you can go to the online help and under the new features they list all the new styles and and changes. This helped me to migrate my 2010 template to 2012 then to 2013. The list is usually at the bottom of the new features page.
Tom Berning
Woolpert, Inc.
Civil 3D 2013
MtnMax700
Message 10 of 11 (125 Views)
Re: 2010 to 2013
04-17-2012 05:04 PM in reply to: MtnMax700
Wha about my CUI's?
Thxs.
David
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
