Has anyone been able to get Keyboard Shortcuts to work in C3D 2010?
For example, ever since C3D 2007, we've had CTRL+B defined as "Move to Back". These shortcuts are defined in a CUI file we load as a Partial CUI, and they worked just fine through three versions of C3D. Now with C3D 2010, I can't get any of my keyboard shortcuts to work.
In the attached image, I'm showing the keyboard shortcuts in my CUI. There is only one definition for CTRL+B - my "Move to Back", and the CUI says it is the active shortcut. However, whenever I hit CTRL+B, it toggles SNAP mode.
It's like this pretty much all down the line... For example, CTRL+SHIFT+T now tries to calibrate the tablet, instead of using the LENGTHEN TOTAL that I have assigned to it in the CUI.
I've tried moving my Partial CUI around in the load order, with no effect.
I cannot find a definition anywhere in any CUI file that assigns CTRL+B to "Toggle SNAP mode". However, I've noticed that the command "Toggle Snap" is defined with a Macro of "^B". This looks like it might be what is trumping my CUI settings.
Anyone else run into this? Did you find any way to fix it?
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.comt
Sinc
