1. DS can only be created in a file that has been named & saved. Save your
file if it's newly created.
2. Right Click (RC) on the DS's entry in Prospector & select Set Working
folder (You need to do this every time you change projects in order to
locate the correct data). Browse to you project folder & hit okay (this will
save each projects DS's to a new folder in the project file structure.
3. RC on the DS's entry in prospector again & select New Data Shortcuts
folder. Provide a folder name & the folder is created in the project's root
folder.
4.RC on the DS's entry in prospector one last time & select Create Data
Shortcuts. Select what you want to share & hit Okay.
To create a reference,
1. Save your file if it is newly created.
2. Make sure the Working folder is set to the current project
3. RC on the DS's entry in prospector & expand the object trees. RC on the
C3D object of your desire & choose Create Reference.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
