I have 2 corridors in my drawing - a structure and a channel. Two different assemblies on different alignments. I want the structure to have a solid hatch and the channel to have a gravel pattern. I have the render material set for the hatch I want for each corridor but they are both showing the same pattern - either the solid or the gravel. When one changes the other changes. I set the codes with hatch to reflect what I want and associated different links (top in one and pave in the other) to each surface. I have the auto rebuild turned off but they are still matching one or the other hatch. What am I missing? Help!
Solved by Jay_B. Go to Solution.
Code Sets control the display of corridors.
If I'm understanding your question, it sounds like you might need a 2nd Code Set so 2 different code sets can be applied to the corridors.
Rt. click on code set name on Settings Tab and choose copy.
Set the hatching the way you want in each of the code set styles and apply as appropriate to the 2 corridors.
