1.
When a line crossing the green colored corridor section is right clicked , and choosing the quick profile option , no profile view is generated.Civil 3d did ask where to generate it so then the area was clicked Still, NO profile. I spent time figuring out how to use the cube at the left bottom corner by rotating so that it shows "TOP " face. When the cube is oriented to TOP face , the drawing is oriented into a line ( like the perspective is a horizon). Initially, I was able to generate the sections (Refer. to quickProfileCorridor6).
2. The another file shows a step to taken to do a quick profile.
I need help so I can continue on with sample lines. Ultimately, road section quantities need to be acquired.
Thanks.
Solved by eyescast. Go to Solution.
Solved by sjg. Go to Solution.
Ya, it is part of my problem description that was initially sent Here are two files , first one is turned to the top face, and the second one is turned to the front face.
Please take note where the line is over the green corridor , the gizmo x-y-z system mode is Turned ON…. Could this be the cause of my problem.
How do get to the gizmo mode settings?
Hi was wrong; **** still needs a solution. I need to turn off the points on the assembly surface. Or change the size that's ok too. how to I change the boundaries so that assembly cross section will look it has cut and fill section?
thanks again.
