AutoCAD Civil 3D General
Active Contributor
eyescast
Message 1 of 7 (363 Views)
1. Quick profile on corridor section AND 2. Corridor surface Boundaries
363 Views, 6 Replies
10-17-2012 10:50 AM
 1.
When a line crossing the green colored corridor section is right clicked , and  choosing the  quick profile option , no profile view is generated.Civil 3d did ask where to generate it so then the area  was clicked Still, NO profile. I spent time figuring out how to use the cube at the left bottom corner by rotating so that it shows "TOP " face. When the cube is oriented to TOP face , the drawing is oriented into a line ( like the perspective is a horizon). Initially, I was able to generate the sections (Refer. to quickProfileCorridor6).
2. The another file shows a step to taken to do a quick profile.
I need help so I can continue on with sample lines. Ultimately,  road section quantities need to be acquired.
Thanks.
Valued Mentor
Valued Mentor
sjg
Message 2 of 7 (350 Views)
Re: 1. Quick profile on corridor section AND 2. Corridor surface Boundaries
10-17-2012 11:31 AM in reply to: eyescast
I noticed your view cube is being showed as looking at the BACK, shouldn't that be TOP? Not sure if that might have something to do with it. Looks like your in some 3D rotation.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Active Contributor
eyescast
Message 3 of 7 (321 Views)
10-17-2012 01:09 PM in reply to: sjg
Ya, it is part of my problem description that was initially sent Here are two files , first one is turned to the top face, and the second one is turned to the front face.
Please take note where the line is over the green corridor , the gizmo x-y-z system mode is Turned ON…. Could this be the cause of my problem.
How do get to the gizmo mode settings?
Valued Mentor
Valued Mentor
sjg
Message 4 of 7 (315 Views)
10-17-2012 01:29 PM in reply to: eyescast
While in model space, type VIEW, maximize Preset Views, select TOP and click Set Current, hit OK. ViewCube or "GIZMO" should read TOP. Then to reset your user coordinate system (XYZ) to World, type UCS, then hit W for world. Then draw a polyline and do a quick profile.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Active Contributor
eyescast
Message 5 of 7 (281 Views)
10-21-2012 01:59 PM in reply to: eyescast
i believe this has work , no issues on this.
thanks
Active Contributor
eyescast
Message 6 of 7 (276 Views)
10-21-2012 02:03 PM in reply to: eyescast
Hi  was wrong; **** still needs a solution. I need to turn off the points on the assembly surface. Or change the size that's ok too. how to I change the boundaries so that assembly cross section will look it has cut and fill section?
thanks again.
Active Contributor
eyescast
Message 7 of 7 (224 Views)
10-30-2012 08:12 AM in reply to: sjg
I was able to fix this problem thanks!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
