Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
vb.net 2012 (cogo) point styles
15 REPLIES 15
Message 1 of 16
kcimos
2679 Views, 15 Replies
all I want to do is get the point style from a user selected COGO point (& then later set it to a different one). This point might be selected along with lines, blocks, and/or whatever. I can get to where I'm dealing with the POINTENTITYobject but one can't access the style from that (or can we?). From what I gather I need to set am AECCPOINT variable from the pointentity object, using the pointentity number property as an index for the aeccpointS index method. THing is, I can't get the AECCPOINTS collection. with is a part of the civil database.
after much research I have the following relevent code:
    Dim PtNumber As Double
    Dim ePoint As PointEntity
    Dim aPoint As AeccPoint
    Dim aPoints As AeccPoints
    Dim aPointsIds As ObjectIdCollection
    Private m_oAeccDb As IAeccDatabase
    <CommandMethod("CDE")> _
    Public Sub ChangeToDemoCivil()        'this is the civil3d version, which works on COGO point styles too
        ACF.SsGetStuff("Select objects to be placed onto DEMO layers:")
        Dim idArray As ObjectId() = ACF.ssResult.GetObjectIds()
        For Each id As ObjectId In idArray
            Using acTrans As Transaction = ACF.Db.TransactionManager.StartTransaction()
                Try
                    ePoint = CType(acTrans.GetObject(id, OpenMode.ForWrite), PointEntity)
                    If Not ePoint Is Nothing Then        'it is a cogo point, so change to appropriate demo style
                        PtNumber = ePoint.PointNumber
                        aPoints = m_oAeccDb.Points
 ACF.getstuff () is an external funtion that stores a list of objectids of selected objects in  ACF.ssResult (as Autodesk.AutoCAD.EditorInput.SelectionSet)
I am getting a fatal error on this:
15 REPLIES 15
Message 2 of 16
Jeff_M
in reply to: kcimos
You don't need to go about it in that fashion. See if this helps:
            Dim ss() As ObjectId = ssResult.Value.GetObjectIds()
            Dim ptEnt As PointEntity
            Using tr As Transaction = doc.Database.TransactionManager.StartTransaction()
                For Each objId As ObjectId In ss
                    ptEnt = objId.GetObject(OpenMode.ForRead, False)
                    Dim ptObj As AeccLandLib.AeccPoint = ptEnt.AcadObject
                    Dim ptStyle As AeccLandLib.AeccPointStyle = ptObj.Style
                    doc.Editor.WriteMessage("Name of the selected point's syle is: " + ptStyle.Name)
                Next
            End Using
Jeff_M, also a frequent Swamper
Message 3 of 16
kcimos
in reply to: kcimos
"Dim ptObj As AeccLandLib.AeccPoint = ptEnt.AcadObject"
that was the key bit of info I needed.
I never would have thouht that a PointEntity had AcadObject property which had a Style property. Now I can look into this aspect of the civil 3d object model, and probably gain enlightenment to other bizarre things.
thanks
Message 4 of 16
kcimos
in reply to: kcimos
OK, now how can I access the point's label style?
Message 5 of 16
kcimos
in reply to: kcimos
OK, I figured that out, I had to go bask to the PointEntity object
Message 6 of 16
kcimos
in reply to: kcimos
opps sorry, its under PointEntity.AcadObject
Message 7 of 16
kcimos
in reply to: kcimos
OK, now I'm trying work out how to test if a point style exists.
All I can find is a similar method that was causing my initial post, for getting the pointstyles from the document this time, which crashes.
I'm looking at the civil3d 2012 developers guide's section on COM
& so to try to retrofit my code to fit with their examples, I add this:
Dim oAcadApp As AcadApplication
Set oAcadApp = ThisDrawing.Application
' Specify the COM name of the object we want to access.
' Note that this always accesses the most recent version
' of AutoCAD Civil 3D installed.
Const sCivilAppName = "AeccXUiLand.AeccApplication.6.0"
Dim oCivilApp As AeccApplication
Set oCivilApp = oAcadApp.GetInterfaceObject(sCivilAppName)
' Now we can use the AeccApplication object.
' Get the AeccDocument representing the currently
' active drawing.
Dim oDocument As AeccDocument
Set oDocument = oCivilApp.ActiveDocument
' Set the viewport of the current drawing so that all
' drawing elements are visible.
oCivilApp.ZoomExtents
 & the first error is that acadapplication is ambigous in the autodesk.autocad.interop
then I see that they are using "THISDRAWING" & "SET". so this documentation for COM is based on VBA, which makes sense, except VB.NET is what the guide is about.
so, anyone know of any way to test if a (point) style exists?
(anyway of copying or saving as one too?)
Message 8 of 16
Jeff_M
in reply to: kcimos
I prefer to stay with the .NET API when possible. This will check if a PointStyle exists. Use the same idea for other styles.
    Function PointStyleExists(ByVal civDoc As CivilDocument, ByVal name As String) As Boolean
        Dim exists As Boolean = False
        Dim styles As PointStyleCollection = civDoc.Styles.PointStyles
        Try
            Dim id As ObjectId = styles(name)
            exists = True
        Catch ex As ArgumentException
        End Try
        PointStyleExists = exists
    End Function
 Or, depending on what you need it for, have it return the ObjectId if you need that.
Message 9 of 16
Jeff_M
in reply to: kcimos
Not sure I understand this question.
Message 10 of 16
Jeff_M
in reply to: Jeff_M
Here's how to test for the existence of a PointLabelStyle:
    Function PointLabelStyleExists(ByVal civDoc As CivilDocument, ByVal name As String) As Boolean
        PointLabelStyleExists = False
        Dim styles As Autodesk.Civil.DatabaseServices.Styles.LabelStyleCollection = civDoc.Styles.LabelStyles.PointLabelStyles.LabelStyles
        Try
            PointLabelStyleExists = True
        End Try
    End Function
Message 11 of 16
kcimos
in reply to: kcimos
anyway of copying a pointstyle. Or would I have to iterate through all the various point style pieces & recreate them in a new style? & If the only way is to iterate and copy each item into a new style using VB variables, is there a way of finding what block, if any, the marker is using?
Message 12 of 16
Jeff_M
in reply to: kcimos
To copy a pointstyle (assuming you have the existing style ObjectId as id):
            Using tr As Transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction()
                Dim style As PointStyle = TryCast(id.GetObject(OpenMode.ForRead, False, True), PointStyle)
                Dim newId As ObjectId = style.CopyAsSibling(style.Name + " - (Copy)")
                tr.Commit()
            End Using
As for the point style marker, use the MarkerType and MarkerSymbolName properties of the style object.
See here for more info: http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/net/html/2953dd7d-c44a-9c3a-7fa0-74a3fef...
Message 13 of 16
kcimos
in reply to: Jeff_M
thanks.
I kinda can't wait 'til monday morning to try it all out.
Message 14 of 16
kcimos
in reply to: kcimos
this:
is causing a fatal error
I was already in a transaction, & I figured this didn't need to be in its own (sub)transaction, so while troubleshooting, since the syntax in your code is a little different from what I'm used to , I figured I'd go ahead & nest it into another transaction, when I pasted this code:
 I get the following error:
Error 1 'Transactio' is not a member of 'Autodesk.AutoCAD.DatabaseServices.Database'
is hostapplicationservices any different than the autocad database (which is what my transactions are started from)? I mean, is it something for civil 3d to allow transactions that work on things such as point styles?
does any of this matter regarding the crashing on copyassibling?
I also tried  opening the pointstyle as write instead of read, ut that didn't help
Message 15 of 16
kcimos
in reply to: kcimos
it figures, as soon as I send my last question, I noticed something that did in fact casue my problem. I was suppyling the objectID from a previous operation which was from a PointEntity
Message 16 of 16
Jeff_M
in reply to: kcimos
This happens to me more than I care to admit.
Rail Community
