Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
station offset label
4 REPLIES 4
CADmgrMike
1020 Views, 4 Replies
I have a station label like the one pictured at the top of my attached file.
I would like to revise it so that in dragged state, it looks like the label at the bottom of the picture. (in the picture, it has been exploded and moved)
The only way I can figure out how to have two labels that look like this is to have two different styles.
One points up and the other points down.
Any ideas?
Thanks.
Mike Porter
https://provostandpritchard.com/
4 REPLIES 4
in reply to: CADmgrMike
Hi Mike,
Is this someting you want to achieve using Civil 3D API / programming ?
If you intend to achieve this using UI tools, then you can probably use two different styles as you said (did you try that ?)
Partha
CADmgrMike
I would like to do it using the UI tools, and I can accomplish it making two different styles.
I was hoping to figure out how to do it with one style if possible.
It seems like a good portion of the time, when you want to use a C3D label in a dragged state, you end up needing mulitple styles to make the label behave correctly depending on which quadrant it's being dragged to.
Thanks for the input.
Mike Porter
kcobabe
You can't hold down cntrl and select the one label and flip it?
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
CADmgrMike
in reply to: kcobabe
I'm assuming that works the same as hovering over the grip and choosing "Rotate label".
Can't believe I didn't think of that. Mental block I guess..... or a brain fart. 🙂
I think that will work.
Thanks.
Mike Porter
Rail Community
