Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
setting scale for sampling sections
4 REPLIES 4
ebeam
456 Views, 4 Replies
Is there a way to select the scale of your cross sections from a sample line? Or is this drawing depentdent. Also how does one change the sheet size in the section view?
thanks
Erin H
4 REPLIES 4
Partha.Sarkar
in reply to: ebeam
Could you clarify on ' which scale' you are talking about here ?
Do you see this scale value in Section / Section view ? A screenshot will help here to understand the context.
Partha
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
ebeam
in reply to: ebeam
Sorry for the confusion. I was meaning the horizontal scale. As is trying to create sections that are at say 10 scale when the drawing is 20 scale. I found where I can adjust the vertical but the horizontal keep defaulting back to the drawing scale.
Erin Haggith
Engineering Assistant
Public Works Engineering
City of Bellingham, WA
360-778-7933
Email: ehaggith@cob.org
My incoming and outgoing email messages
are subject to public disclosure requirements
per RCW 42.56
Partha.Sarkar
in reply to: ebeam
Hi Erin,
Thanks for the clarification. But, I don't see any such settings or control is available and I think its as designed and calculated based on the drawing scale where as the vertical scale could be controlled as you understand, many a times change in elevation would be a fraction of horizontal distance and hence that's necessary to reduce the vertical scale.
Hope this explains.
Partha
Partha Sarkar
ebeam
in reply to: ebeam
Yes thank you it does explain and what I had concluded myself.
Appreciate your time.
Erin Haggith
360-778-7933
per RCW 42.56
Rail Community
