You're welcome, Josh.
Like you, I thought a Set was necessary for this since you are assigning an
object to something. But since it is a property we are assigning the object
to, it isn't needed (or wanted, evidently). I've been playing with .NET (VB
& C#) for too long I guess, neither of which use the Set statement, so I'm
drawing a blank for a good explanation....
I do know that when assigning a variable which has been cast as an object,
you MUST use Set.
"jlund" wrote in message news:5913375@discussion.autodesk.com...
> Thanks, Jeff. That did it!
> When should the Set keyword be used? This is something the frequently
> trips me up. Are there some guidelines for using it?
> Thanks,
> Josh
