Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
select alignment via ObjectId.
1 REPLY 1
joantopo
395 Views, 1 Reply
Hi.
I have a datagridview with all alignments included in the drawing file.
If I choose an alignment in datagridview, I have Id of that alignment.
I have a button, and I would like that if i press that button then selects that alignment in the drawing(graphic).
I would like that there was only one object selected, and if there are more selected objects before,then un-selected them.
I have seen in internet, the code snipset:
"Autodesk.Autocad.Internal.Utils.SelectObjects(objectId[ ] Ids)"
Is it obligatory that objectId be able a List or array?
and
"Editor,SetImpliedSelection"
But I don´t understand them.
Are threre any full samples about his?.
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
1 REPLY 1
joantopo
in reply to: joantopo
 Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
          Autodesk.AutoCAD.DatabaseServices.ObjectId[] arrayId={variables_globales.Idgeneral};
          ed.SetImpliedSelection(arrayId);
 Solved.
Rail Community
