AutoCAD Civil 3D Customization
Valued Contributor
fallright
Message 1 of 4 (195 Views)
read anonymous blocks
195 Views, 3 Replies
10-23-2012 03:54 AM
I have the follwoing error in C3D R2013.
Unable to cast object of type 'Autodesk.AutoCAD.DatabaseServices.BlockTableRecord' to type 'Autodesk.AutoCAD.DatabaseServices.BlockReference'.
When casting from a number, the value must be a number less than infinity
Make sure the source type is convertible to the destination type
My code is:
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.LayerManager
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.PlottingServices
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.Civil.DatabaseServices
Imports Autodesk.Civil.ApplicationServices
Imports Autodesk.Civil.DatabaseServices.LabelGroup
Imports Autodesk.Civil.DatabaseServices.Styles.LabelSetStylesRoot
Imports Autodesk.Civil.Runtime
Imports Excel = Microsoft.Office.Interop.Excel
Imports Microsoft.VisualBasic.FileIO.FileSystem
Imports System.IO
Imports System.Convert
Imports Microsoft.VisualBasic.Strings
Imports System.Runtime.InteropServices
Imports System.Collections.Specialized
Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim btable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
            If btable.Has("vbredakdettek") Then
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(btable("vbredakdettek"), OpenMode.ForRead), BlockTableRecord)
                For Each refId As ObjectId In btr.GetAnonymousBlockIds()
                    myBlock = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockReference)
Alfred.NESWADBA
Message 2 of 4 (193 Views)
Re: read anonymous blocks
10-23-2012 04:01 AM in reply to: fallright
I have not tried it, but I guess that the function .GetAnonymousBlockIds returns ObjectIDs of BlockTableRecords.
So change your last shown code line to:
      Dim myBlockBTR as BlockTableRecord = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockTableRecord)
...does that work?
- alfred -
Alfred NESWADBA
Valued Contributor
fallright
Message 3 of 4 (187 Views)
10-23-2012 05:53 AM in reply to: Alfred.NESWADBA
that works, but my code continues with:
                    Dim myBlockBTR As BlockTableRecord = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockTableRecord)
                    'myBlock = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockReference)
                    Dim owner As BlockTableRecord = DirectCast(tr.GetObject(myBlock.OwnerId, OpenMode.ForRead), BlockTableRecord)
                    If owner.IsLayout Then
                        If myBlock.Name.ToUpper = "VBREDAKDETTEK" Then
 How can I then get "myblock" ?
Alfred.NESWADBA
Message 4 of 4 (177 Views)
10-23-2012 08:42 AM in reply to: fallright
use the function myBlockBTR.GetBlockReferenceIDs to get the ObjectIDs pointing to the blockreferences then.
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
