I am in the process of creating a modified report for Sturctures Only
The current call in the original report calls the Structure Type, I would like to get the description instead.
Does anyone know the function call for getting the Sturcture Descrition out of the pipe network.
<xsl:variable name="StructType" select="landUtils:getStructType(.)" />
You're welcome.
BTW, Welcome to the forums! Now that you've found them have a look around.
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
civil 3d 2012
write permission was not set correctly for the folder containing the Toolbox xml file.... C:\ProgramData\Autodesk\C3D 2012\enu\Data\Toolbox
thanks again for the help
