Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
get surfaceBreaklines.
11 REPLIES 11
Message 1 of 12
joantopo
709 Views, 11 Replies
Hi.
I have this:
     for(int i=0;i<= tinSurface.BreaklinesDefinition.Count-1;i++)
 I have each breakline sets, but I want each breakline of each breakline set(breaklinesDefinition).
I can do this:
 Autodesk.Civil.DatabaseServices.SurfaceBreakline sfb = default(Autodesk.Civil.DatabaseServices.SurfaceBreakline);
                                    SurfaceBreakline sfb= trans.GetObject(id,OpenMode.ForWrite) as SurfaceBreakline;
 But how can I get ObjectIdcollection of surfaceBreakline of one breaklinesDefinition?
I have seen that there is "AECC.Interop.Land.SurfaceBreaklines". Do I have to use this?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
11 REPLIES 11
Message 2 of 12
Jeff_M
in reply to: joantopo
Yes, you actually need to use the BreaklineEntities property using COM. I have some code at home that shows how this can be done using late binding so the COM Interops don't need to be referenced. I will post it when I return from AU, unless you get it figured out first.
Jeff_M, also a frequent Swamper
Message 3 of 12
joantopo
in reply to: Jeff_M
Thanks.
I will wait then because I am very bad with COM.
Message 4 of 12
Jeff_M
Here's that code, Joan. It is an extension method for a TinSurface which returns the Entity ObjectIds of the specified SurfaceOperationBreakline object.
//a command to test against
        [CommandMethod("brkTest")]
        public void brktestcommand()
            CivilDocument civdoc = CivilApplication.ActiveDocument;
            using (Transaction tr = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
                TinSurface surf = (TinSurface)civdoc.GetSurfaceIds()[0].GetObject(OpenMode.ForRead);
                SurfaceOperationAddBreakline brkln = surf.BreaklinesDefinition[0];
                ObjectIdCollection brkentsIds = surf.GetBreaklineEntityIds(brkln);
                tr.Commit();
//and the extension method which should go in it's own static class
    public static class SurfaceExtensions
        public static ObjectIdCollection GetBreaklineEntityIds(this CivDb.TinSurface surf, CivDb.SurfaceOperationAddBreakline brklineOp)
            string name = brklineOp.Description;
            ObjectIdCollection result = new ObjectIdCollection();
            object tinsurf = surf.AcadObject;
            object brklines = (object)tinsurf.GetType().InvokeMember("Breaklines", System.Reflection.BindingFlags.GetProperty, null, tinsurf, null);
            object[] args = new object[1];
            for (int j = 0; j < (int)brklines.GetType().InvokeMember("Count", System.Reflection.BindingFlags.GetProperty, null, brklines, null); j++)
                args[0] = j;
                object brklin = brklines.GetType().InvokeMember("Item", System.Reflection.BindingFlags.InvokeMethod, null, brklines, args);
                string desc = (string)brklin.GetType().InvokeMember("Description", System.Reflection.BindingFlags.GetProperty, null, brklin, null);
                if (desc == name)
                    object[] ents = (object[])brklin.GetType().InvokeMember("BreaklineEntities", System.Reflection.BindingFlags.GetProperty, null, brklin, null);
                    for (int i = 0; i < ents.GetLength(0); i++)
                        ObjectId id = DBObject.FromAcadObject(ents[i]);
                        result.Add(id);
            return result;
Hope that helps.
Message 5 of 12
joantopo
in reply to: Jeff_M
Thanks a lot ,Jeff.
Once I have Id entity, could I delete that breakline?
 deletebreakline method  doesn´t exist.
I have this:
    Autodesk.Civil.DatabaseServices.TinSurface tinSurface = trans.GetObject(surfaceId, OpenMode.ForWrite) as Autodesk.Civil.DatabaseServices.TinSurface;
                        //obtenemos todos los id de las líneas de rotura de la superfície y comprobamos si coincide con el Id de la entidad seleccionada
                         if (tinSurface.BreaklinesDefinition.Count > 0) //si hay algún conjunto de líneas de rotura
                             SurfaceDefinitionBreaklines brkdefs = tinSurface.BreaklinesDefinition;
                             for (int i = 0; i <= brkdefs.Count - 1; i++)
                                 SurfaceOperationAddBreakline brklines = brkdefs[i];
                                 ObjectIdCollection coll = new ObjectIdCollection();
                                 coll = ExtensionMethods.SurfaceExtensions.GetBreaklineEntityIds(tinSurface, brklines);
                                 //lo añadimos todos a la colección principal.
                                 foreach (ObjectId id in coll)
                                     todosIDbrkl.Add(id);
                         if (todosIDbrkl.Contains(entRes.ObjectId) == false) //si la entidad seleccionada no existe como línea de rotura de la superficie.
                             MessageBox.Show("La entidad seleccionada no pertenece a la superfície como línea de rotura.", "AVISO", MessageBoxButtons.OK, MessageBoxIcon.Warning);
                             return;
                        //if exists Id entity, erase that breakline
                            // rebuild the surface
                            tinSurface.Rebuild();
 I have other function to delete all breaklines definitions and create new breaklinesdefinitions. Perhaps I can call this function and put Id as parameter to not include this entity as breakline.
Message 6 of 12
joantopo
I don´t understand why Civil 3D give us possibility add 2 or more times the same entity as breakline in the surface. ¿?
Message 7 of 12
Jeff_M
@joantopo wrote:
Thanks a lot ,Jeff.
You're welcome. This is what I have done as well. There is no good way to do this with the current API, at least not that I have found.
Message 8 of 12
joantopo
in reply to: Jeff_M
Hi Jeff. Sometines I get a bug in your GetBreaklineEntityIds() method: Here, there is a screenshoot in VS: http://s22.postimg.org/yarcpmoht/capturada.jpg
Message 9 of 12
joantopo
it is a "TargetInvocationException".
Message 10 of 12
joantopo
COMPlusExceptionCode= -532462766
Message 11 of 12
Jeff_M
Can you send me the drawing you get this error in?
Message 12 of 12
Jeff_M
in reply to: Jeff_M
Not sure, but I think this may come from looping through breaklines whose Autocad entities have been erased but the surface retains them if the Build operations "Copy deleted dependent objects" is set to true. When this happens there is no object to get an objectid for. If this is what you are seeing, adding a try{} catch{} should work around that. If you want to add the object back, I think that can be done with the .NET Breakline object....would have to do some testing, but I can't do that right now.
Rail Community
