02:01 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is anyone else having problems using custom pipe properties in pipe label expressions in 2013? I have some expressions relating to stub callouts and the ones that directly reference the custom properties lose that reference every so often.
For example I have and expression called "STUB-Riser-Length2d" which is defined as "{Riser Length} / SQRT(2)" where "Riser Length" is the custom pipe property. Every week or so it changes to "/ SQRT(2)".
I haven't been able to find the pattern as to exactly when this happens yet. All expressions not referencing custom properties seem to be holding steady. The pipe catalog is on a shared drive on the network, if that makes any difference.
