Civil 3D 2014
I need to edit some items in the Report facility. Found the VB dot net source code under:
C:\ProgramData\Autodesk\C3D 2014\enu\Data\Reports\Net\Source
Opened it in Visual Studio 2013 for Windows Desktop
Set the paths of the references.
Set the build to a different folder.
On Build Solution there is a long list of this error:
GetStationStringWithDerived is not a member of Report.ReportUtilities
Looks like the source provided to users is not the actual source - correct?
How do I correct this error?
I am much more proficient in C#. Is the reporting source project available in C#?
I was considering using Autodesk support to make a support request for this problem. But this kind of request is probably not covered by standard support - correct? If I want Autodesk support for this kind of problem I probably need to be a member of the ADN - correct?
All I really want is to solve the GetStationStringWithDerived method error and continue to edit the source.
The other questions can be ignored. I just got carried away.
Thx for reading,
Cheers for now,
Kevin.
Solved by Jeff_M. Go to Solution.
The reports have always been finicky when loading them the first time. I recall running into this, but not sure what, exactly, I did to correct it. The function IS in the code (I just checked the installer and it's all in there) but I see that I have modified the ReportUtilities module since installing so I had to have done something...I'm just not seeing what that might have been in a quick look.
Yes, it's now late here (11:30 p.m., California) headed for bed now.
Hi Kevin,
I did a quick try using Visual Studio 2012 and it seems to be building the "C3DReport.dll" without any issue.
What's the targeting .NET framework you selected in Visual Studio 2013 ?
4 ... tried targeting to 4.5 and 4.5.1 ... same error ...
Plus ...
The error message is correct on my side. On my side ReportUtilities.vb does not include a method named GetStationStringWithDerived.
This method is used about 100 times.
Does your ReportUtilities.vb include a method named GetStationStringWithDerived?
If so .. then I have the incorrect source code ... would be great if you could make it available somehow (not just ReportUtilities.vb , the entire Project).
Thx for the asistance.
Hi Kevin,
I can arrange to upload this, but I am wondering how the source could be different in your installation ?
How about others ? Could anyone rebuild this source successfully ?
Partha
No problems here. Copied source to a writable location, added a reference path to resolve references, build, done.
Looks like I have the incorrect source.
Would be great if someone could zip it, upload to cloud, make public and share ..
please ...
Thx,
Kevin.
Thx Jeff .. is there any chance you can attach the sln file from the parent folder?
