Thanks to JeffM, I have a getdoc routine I can use over and over, allowing it to find the correct Civil 3D version. It works up to Civil 3D 2014, R19.2, and appends .10.3.
Civil 3D 2015 is R20.0 but what is the number after that? I tried .11.0 and it doesn't work.
Any help will be appreciated greatly!
Tim
Solved by Jeff_M. Go to Solution.
10.4 for 2015, Tim.
In order to find this in the next version, this is where I go to look:
The number following Civil Engineering with a well placed decimal is the number you need, knowing that the latest installed version is the last one in the list.
Thanks, Jeff!
