I need to dump the coordinates of alignment and profile, but I cannot found the reference of the command list of both of .NET API and ObjectARX API. I have some questions and will appreciate if anyone can give me some advice about them.
1 Where can I find the reference of the commands?
2 Do .NET API and ObjectARX API both provide the commands to access the coordinates alignment and profile?
3 What is the difference between them? I mean the complexity and time to learn.
4 To access coordinates or dump coordinates to a text file, which one is easier to code?
5 Do they provide the commands to write data into a text file? Or can I use standard i/o in visual studio?
Press F1 in Civil 3D and in the contents look for Developer Help.
I'd do .NET, ObjectARX is C++ based and I haven't attempted to program in it.
Due to advances in programming c#.NET is easier to learn and use.
Look at the reports source code that comes with the program: C:\ProgramData\Autodesk\C3D 2011\enu\Data\Reports\Net\Source One of the reports dumps to a file (html, doc, xls) or can easily be modified to a text file.
You can use the standard i/o in visual studio.
