Good afternoon everyone!
I've already asked this question at the swamp but thought I'd ask here as well. Is it possible to delete a survey figure from the database with VB .NET? I tried using the .erase method of the SurveyFigure object, but that only appeared to remove it from the drawing and not the database.
Thanks in advance for any help or sample code you can provide!
Solved by Jeff_M. Go to Solution.
Haven't tried it, but Remove appears to be the thing you'd want to use:
