Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Updating VBA code to vb.net reference issues
1 REPLY 1
ralstogj
528 Views, 1 Reply
Hi
I have been going thru the ADN video on updating code from vba to vb.net and have gotten everything into vb.net but the references do not seem to work the path names are not the typicsl ones I would expect and when I change them they convert back to the original paths that do not seem to work any ideas.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
1 REPLY 1
andrewpuller3811
in reply to: ralstogj
From the reference versions, it looks like you are developing on 2012.
If that is so, check out this post which covers issues with 2012 com references, including a fix.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/NET-on-C3D-2012-SP1/m-p/3239124#M6012
or check out this post on adn dev blog on the same issue with fixes.
http://adndevblog.typepad.com/infrastructure/2012/05/cannot-build-civil-3d-2012-com-with-net-code-af...
Hope this is the solution you are after.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
