Trouble with C3d 2012 COM
AnthonyGraham7907
AnthonyGraham7907
Hello All,
I am having trouble getting the COM application objects, after trying a number of different methods that I managed to find in the (scant) literature and elsewhere.  I am using VB2010, w7 64 bit and C3D 64 bit.
The code in question reads...
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AECC.Interop.UiLand
Imports Autodesk.Civil.ApplicationServices
Module Civil3DObjects
FriendConst ACAD_VERSION AsString = "AutoCAD.Application"
FriendConst CIVIL3D_VERSION AsString = "AeccXUiLand.AeccApplication.9.0"
'net
Friend netDOC AsCivilDocument
Friend netEDITOR AsEditor
'com
Friend comAcadApp As Autodesk.AutoCAD.Interop.IAcadApplication
Friend comAeccApp As Autodesk.AECC.Interop.UiLand.IAeccApplication
Friend comAeccDoc AsIAeccDocument
Friend comAeccDB As Autodesk.AECC.Interop.Land.IAeccDatabase
FriendFunction GetCOMobjects() AsBoolean
'returns true if successfull
        GetCOMobjects = False
'comAcadApp = TryCast(Application.AcadApplication, AcadApplication)
'comAeccApp = TryCast(comAcadApp.GetInterfaceObject(CIVIL3D_VERSION), AeccApplication)
'If comAeccApp Is Nothing Then
'    Throw New COMInstanceException("Unable to retrieve interface for Civil Application.", CIVIL3D_VERSION)
'End If
Try
If IsNothing(comAcadApp) Then
            comAcadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
EndIf
Catch ex As System.Exception
            MsgBox("Cannot load AutoCAD Application")
Return False
EndTry
IfNot comAcadApp IsNothing Then
Try
                comAeccApp = comAcadApp.GetInterfaceObject(CIVIL3D_VERSION)
                comAeccDoc = comAeccApp.ActiveDocument
                comAeccDB = comAeccApp.ActiveDocument.Database
                MsgBox("Cannot load Civil3D Application")
Return False
EndTry
EndIf
Return True
EndFunction
Everything goes pear shaped at...
         where CIVIL3D_VERSION = "AeccXUiLand.AeccApplication.9.0"
The project references are  shown in the attached image.
This has stumped me for a couple of days now and I am sure that I will feel like a goose for missing something simple.  Please help.
Anthony
Jeff_M
Using the GetInterfaceObject() method has the potential to try to use the wrong running instance of AutoCAD if there is more than one running. This was the case in older products, not sure about 2012 because we use the following code which always works for the running instance it is called in. (Which means I'm not sure why your code fails, it looks like it should be fine, just this method takes the place of the GetInterfaceObject())
comAeccApp = New IAeccApplicationClass()
comAeccApp.Init(comAcadApp)
 From there you can set the document and database objects.
AnthonyGraham7907
Thanks Jeff,
I inserted the following code as a replacement for the GetInterfaceObject...
               Dim comAeccApp As New Autodesk.AECC.Interop.UiLand.AeccApplication
                comAeccApp = New AeccApplication
and got an error message saying that FDO.dll could not be found.  I found FDO.dll and updated the device path in C3D to look in the correct location (had to swap "...\FDO\BIN\" for "...\BIN\FDO") and the code ran through as it was meant.
Thanks again Jeff, you are a lifesaver.
Anthony
peterfunkautodesk
Anthony,
Unless you're using something that isn't exposed to .NET I would switch to VB.NET instead. The .NET API is 5-10 times faster than the COM API, and all new API work is being done on the .NET side.
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
