AutoCAD Civil 3D Customization
theonlynelly
Message 1 of 2 (248 Views)
The Sync of AutoCAD Civil 3D 2012, AutoLisp, SQL
248 Views, 1 Replies
10-31-2012 06:27 PM
Dear all, i have a question..
From the bridge 3D model (produced by AutoCAD Civil 3D 2012), my professor told me to make a user interface from it. In the UI, for example if i click the beam of the bridge, it will pop-up the properties of the beam.
He doesn't told me how to do that, i just know that once he said that i have to use AutoLisp & SQL. As a newbie, i ask this to get enlightenment from all of you. I hope someone can guide me to solve my problem.
Thank you in advance :smileyembarrassed:
ADN Support Specialist
Partha.Sarkar
Message 2 of 2 (239 Views)
Re: The Sync of AutoCAD Civil 3D 2012, AutoLisp, SQL
11-01-2012 07:55 AM in reply to: theonlynelly
Civil 3D Bridge modeler is a Lab Tool and it doesn't have exposed API to access properties. I am not sure if you are referring to same bridge tool here or the Civil 3D subassembly / assemblies which you can use to build a bridge section. In any case, I would suggest to use .NET (VB / C#) to build your application instead of AutoLISP. And for that, start with the AutoCAD .NET API tutorials. Here are some useful resources -
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
http://adndevblog.typepad.com/autocad/
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8007696
http://adndevblog.typepad.com/infrastructure/
Cheers,
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
