Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
SettingsAbbreviationSuperelevation dubt
2 REPLIES 2
joantopo
380 Views, 2 Replies
I´m trying to do a process called "Read Abbreviatures Superelevations" to read abbreviatures:
http://docs.autodesk.com/CIV3D/2013/ENU/API_Reference_Guide/html/28c85f39-be6d-59ef-ebb8-745f378aa3b...
 public static void Read_Abbreviatures_Superelevations()
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                    using (Transaction trans = db.TransactionManager.StartTransaction())
                        Autodesk.Civil.Settings.SettingsAbbreviationSuperelevation Abreviatura = Autodesk.Civil.Settings<SettingsAbbreviation>() as SettingsAbbreviationSuperelevation;
                      variables_globales.PeralteMaxInicio = Abreviatura.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.BeginFullSuper);
                     variables_globales.PeralteMaxFinal = Abreviatura.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.EndFullSuper);
                     variables_globales.BombeoInicio =  Abreviatura.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.BeginNormalCrown);
                     variables_globales.BombeoFinal =  Abreviatura.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.EndNormalCrown);
                    variables_globales.InicioAlin= Abreviatura.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.BeginOfAlignment);
                    variables_globales.FinAlin = Abreviatura.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.EndOfAlignment);
However, I have a trouble with this line:
 How should be this line code to be OK?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
Jeff_M
in reply to: joantopo
            CivilDocument civdoc = (CivilDocument)CivilApplication.ActiveDocument;
            SettingsAbbreviationSuperelevation superabbr = (SettingsAbbreviationSuperelevation)civdoc.Settings.DrawingSettings.AbbreviationsSettings.Superelevation;
            string beginfull = superabbr.GetSuperelevationAbbreviation(AbbreviationSuperelevationType.BeginFullSuper);
joantopo
in reply to: Jeff_M
Thank you very much, Jeff.
Rail Community
