Hi
I am trying to set the value of the exisitng userdefined property "Address" of Parcels using the com method SetUserDefinedPropertyValue but have had not luck. I have looked at the following help sections but that has not helped.
Does anyone have and example code sample they can share.
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXLandLib__IAeccParcel.htm
page 85 here http://images.autodesk.com/adsk/files/civil_api_developers_guide0.pdf
Hi Justin,
I have created a blog post on your question and added a code snippet demonstrating how to set Parcel UserDefined Property using Civil 3D API.
Please check the following:
Set Parcel UserDefined Property using Civil 3D API
http://adndevblog.typepad.com/infrastructure/2012/08/set-parcel-userdefined-property-from-api.html
