I have checked both methods:
But with both cases ribbon of alignment appears very fast but selection alingment in graphic is very very slow...
What happens?
Solved by joantopo. Go to Solution.
I don´t understand why if I do select and zoom entity, program takes few time to select alingment :
Autodesk.AutoCAD.Internal.Utils.SelectObjects(arrayId); Autodesk.AutoCAD.Internal.Utils.ZoomObjects(false); System.Windows.Forms.Application.UseWaitCursor = false;
but if I only select alignment, it takes a lot of time.
Solved, the last line should be:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.UpdateScreen();
or with commandFlag redraw.
