Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Select alignments is very very slow (API)
2 REPLIES 2
joantopo
376 Views, 2 Replies
I have checked both methods:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/select-alignment-via-ObjectId/td-p/4517...
But with both cases ribbon of alignment appears very fast but selection alingment in graphic is very very slow...
What happens? Smiley Frustrated
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
joantopo
in reply to: joantopo
I don´t understand why if I do select and zoom entity, program takes few time to select alingment  :
 Autodesk.AutoCAD.Internal.Utils.SelectObjects(arrayId);
         Autodesk.AutoCAD.Internal.Utils.ZoomObjects(false);
          System.Windows.Forms.Application.UseWaitCursor = false;
but if I only select alignment, it takes a lot of time.
joantopo
Solved, the last line should be:
 Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.UpdateScreen();
 or with commandFlag redraw.
Rail Community
