Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Sample Multiple Surfaces for Multiple Alignments
3 REPLIES 3
410 Views, 3 Replies
I need to figure out a way to sample multiple surfaces for multple alignments.
Example 1: I am creating cross sections for a river dredge showing the pre-dredge bathymetry, design dredge elevation, and post-dredge bathymetry results. I have 100's of alignments that I need to sample 3 surfaces and display in profile view. Due to the clients requirements for display, using the cross section tools don't work for me, so I have resorted to using a seperate alignment for each cross section.
Example 2: Working in a subdivision with many utility alignments it would save quite a bit of time to be able to choose a group of alingments and sample multple surfaces in just a few clicks.
I am thinking since this is such a redundant process that it could be easily scripted. Does anyone have any experience with this?
3 REPLIES 3
If you know .NET it can be done with Profile.CreateFromSurface.
There is an example in the AutoCAD Civil 3D 2013 API Developer's Guide "Creating a Profile From a Surface"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19337648&linkID=9240698
Would have to modifiy it to iterate through selected alignments and add each selected surface.
Thanks for that. I was hoping someone had already done the work for me. It's definitely time for a mid-years resolution to dig in and start working with .NET
I follow Chrisotpher at civil3dreminders but do you know of any other necessary resources for .net programming?
This looks like a really good place to start...
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
Rail Community
