how do you delete an input/output Parameter
Solved by Civil3DReminders_com. Go to Solution.
Select the row and press delete. You can select the row by selecting a non-editable field in the row.
On a side note I really don't like the hidden UI that that UI/UX designers use today, especially for technical programs.
as simple as that!!!
yes there is a lot they could add, intellsence, pan and zoom to the preview, looping to name a few.
But I guess they have other fires to put out.
thanks
opps.....another delete question.
trying to embed a new element, however it links it to the last element in the flow chart.
How do I delete this link so that I can reestablish correct ones.
You don't delete it, you go into the properties and change which points it utilizes.
Also you might want to post in the General Civil 3D forum where you'll get quicker answers for SAC related posts.
