AutoCAD Civil 3D Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Profile View Band Update
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I edit a profile by adding a PVI, the profile view bands update poorly. The band down station is removed and the new PVI band label isn't added. Is there a way to force Civil 3D to refresh the bands programattically? Going into the profile view properties refreshes the band to show correctly, but I don't think that's an acceptable solution.
Christopher
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Re: Profile View Band Update
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Chris,
I don’t see ProfileView has any API to Refresh or ForcreRefresh.
Did you try to use send command “regen” via API ? Does that help ?
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, I tried regen, but that didn't work.
Christopher
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Chris,
Could you send me the code snippet and related DWG file to investigate this issue ? You can drop me an email with these files, I will look into it.
Partha Sarkar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Partha,
Below is an extraction of the code that I am using. There are also some transient graphics that get drawn, but the code is below. The Regen and UpdateScreen was primarily used to get rid of any lingering temporary objects. Replace the station and elevation to a value that works with the profile you test this on.
private void RunCommand()
Database db = acadApp.Application.DocumentManager.MdiActiveDocum
Editor ed = acadApp.Application.DocumentManager.MdiActiveDocum
using (Transaction tr = db.TransactionManager.StartTransaction())
ObjectId profileObjId = civDoc.SelectProfile("Select profile section to edit: ", out profView);
Profile profSection = profileObjId.GetObject(OpenMode.ForRead) as Profile;
profSection.PVIs.AddPVI(editPtForm.PointStation, editPtForm.PointElevation);
ed.Regen();
ed.UpdateScreen();
tr.Commit();
public static ObjectId SelectProfile(this CivilDocument civDoc, string prompt, out ProfileView profView)
Editor ed = Application.DocumentManager.MdiActiveDocument.Edit
PromptEntityOptions pops = new PromptEntityOptions("\n" + prompt);
profView = null;
PromptEntityResult profileRes = ed.GetEntity("AeccDbVAlignment", pops, "\nYou must select a Profile:");
if (profileRes.Status == PromptStatus.OK)
// Get the profile view of the profile.
Profile prof = profileRes.ObjectId.GetObject(OpenMode.ForRead) as Profile;
Alignment align = prof.AlignmentId.GetObject(OpenMode.ForRead) as Alignment;
profView = align.GetProfileViewByPoint(profileRes.PickedPoint
return profileRes.ObjectId;
return ObjectId.Null;
Christopher
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Chris,
I am not able to compile your code using Civil 3D 2013 assemblies. Which release of Civil 3D are you using ?
what is this civDoc ? COM ? or .NET ?
Some other unresolved variables - editPtForm
rofView = align.GetProfileViewByPoint(profileRes.PickedPoint).GetObject(OpenMode.ForRea
Your input required here to resolve the above issues.
Partha Sarkar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here's the a complete code example that should work without modification. The previous code utilized some extensions on the CivilDocument to make cleaner code.
http://blog.civil3dreminders.com/2012/09/adding-pr
Christopher
