• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D Customization
    Point Elevation not Point Location Z
    255 Views, 5 Replies
    08-10-2011 02:59 PM
    I am trying to write a routine that exports point to a CSV file. I would like the Point Elevation, but I only see the Z location property. Here is the code. Often our points are at a elevation of zero, but the elevation property is at the design grade, so the Location would not be correct. What am I missing?
            <CommandMethod("ExportPoints")> _
            Public Sub ExportPointsToCSV()
                Dim myDoc As Document = AcadNETApp.DocumentManager.MdiActiveDocument
                Dim myCivilDoc As Autodesk.Civil.ApplicationServices.CivilDocument
                myCivilDoc = CivilApplicationManager.ActiveCivilDocument
                Dim mySW As New IO.StreamWriter("C:\test.csv")
                Using myTrans As Transaction = myDoc.TransactionManager.StartTransaction
                    For Each myPointID As ObjectId In myCivilDoc.GetAllPointIds
                        Dim myPoint As PointEntity = myPointID.GetObject(OpenMode.ForRead)
                        mySW.WriteLine(myPoint.PointNumber & "," & _
                                       myPoint.Location.Y.ToString & "," & _
                                       myPoint.Location.X.ToString & "," & _
                                       myPoint.Location.Z.ToString & "," & _
                                       Left(myPoint.FullDescription, 15))
                    Next
                End Using
                mySW.Flush()
                mySW.Close()
                mySW.Dispose()
            End Sub
     Thank you,
    Mike
    Please use plain text.
    Re: Point Elevation not Point Location Z
    08-10-2011 03:27 PM in reply to: mikekillion
    The Z is the point's elevation. Where it is displayed in the drawing is controlled by the style, so the Location.Z should never change due to how it's displayed.
    08-10-2011 03:31 PM in reply to: Jeff_M
    Thanks for taking a look at this Jeff.
    When I select a point in the drawing and view the properties, it shown me a northing, easting and elevation. When I run this routine, the elevation of every point is 0, regardless of the elevation shown in the properties dialog. How do I retrieve the point elevation displayed in the drawing?
    Mike.
    08-10-2011 05:27 PM in reply to: mikekillion
    Oops, sorry about that! I really should learn to not post when I'm in a hurry.
    The PointEntity is a newer (2011) addition to the .NET API and it appears it is not completely done. I've always used the COM API to get the elevation which IS a property of the AeccPoint object.
    08-10-2011 05:29 PM in reply to: Jeff_M
    Thanks Jeff. I knew I was missing something. I will give that a try.
    MIke
    08-10-2011 11:38 PM in reply to: mikekillion
    Thanks again Jeff. That was the guidance I needed.and I was able to get the code below to work.
                'This routine still relies on the COM Interface in order to get the Point elevation, not the location
                Dim myCivilDoc As AeccDocument
                myCivilDoc = CivilApplicationManager.COMActiveCivilDocument
                Dim myProjectInformation(2) As String
                myProjectInformation = myAcadApp.getProjectInformation(myDoc)
                Dim sPath As String = myProjectInformation(2) & "\08 Site Construction\Point Files\" & myProjectInformation(1) & "." & Now().ToString("yyyy-MM-dd") & ".csv"
                MsgBox(sPath)
                Dim mySW As New IO.StreamWriter(sPath)
                Dim myPoints As AeccPoints = myCivilDoc.Points
                    For Each myPoint As AeccPoint In myCivilDoc.Points
                        mySW.WriteLine(myPoint.Number & "," & _
                                       myPoint.Northing & "," & _
                                       myPoint.Easting & "," & _
                                       myPoint.Elevation & "," & _
                    Next
                End Using
                mySW.Flush()
                mySW.Close()
                mySW.Dispose()
            End Sub
     I did notice that the resulting file was not in point number order. Is there a way to easily retrieve the myCivilDoc.Points collection already sorted without assigning it to an array?
    Thanks again. I'd been struggling with that for far longer than I hoped, and I finally worked through the COM .NET confusion I have had in migrating from VBA.
